Custom Size Sheet Drawing
Could I custom the size sheet of my drawing?
My drawing is around 1350mm*400mm.
The max size is A0 and I need to print my drawing at the real size.
How could I do?
Replies (66)
MattPerez314
Anto, i don't believe that functionality is currently supported.  Sheet Settings can be found at the bottom center of the Canvas, but you can only change the A sheet sizes.  About the only thing you can do is scale the DWG or DXF if one of the A sizes has the same aspect ratio as your final size, which it isn't.  I don't know of any sheet size standards that match yours.  Is it a standard?
Hello Matt,
Thanks for answering. The size that I need is not standard. I need a sheet of 1350 mm * 400 mm... I don t want to use a scale as i want to print my drawing with the real size.
Maowen_Zhang
@Anonymous, @MattPerez314 is right about this, currently Fusion 360 Drawing doesn't support sheet size custimization. One workaround is output the DWG file and then use AutoCAD to modify the sheet size and print out format such as PDF. I understnad using an more application makes the whole workflow not that smooth, please let me know if you need any support, such as help generate a PDF with the size your need for one specified drawing.  Thanks for sharing with us!
Lori Zhang (Fusion Development)
Eng-OS
Same issue here except in my case it's a "semi -standard" paper size. The printer we have uses some "super B" paper which are between B and C size...
dmartinS68QJ
I ran into this issue too, i want to print 1:1 scale on a plotter and model is larger than all current formats.  I found a request over in IdeaStation requesting ability to create custom paper sizes.  Add your votes to support the interest.
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/custom-sheet-size-in-drawings/idi-p/...
-Dan
oliver
Hi, I have spent a day or two playing with this software to see if it is a credible alternative to SW. For the following reasons I cannot use it:
  • You cannot create configurations of parts in one file, allowing the use of different configurations in different models.
  • You cannot use a component that is generated in a model (assembly) in other assemblies without cutting the ties between the instances, i.e. you cannot make changes to a component in assembly A1 and have the same part in A2 receive the updates to the component.
  • You cannot export drawings of parts in 1:1 that are bigger than A0! This seems like madness, I build furniture from my models (real human sized furniture) and table tops for instance cannot be restricted to A0 for DXF export.
  • Where is the DXF export, is it just DWG?
Very disappointing really, perhaps I'm missing something?
So I have a somewhat convoluted and imperfect solution for anyone who comes looking:
  1. Scale your drawing so that it fits onto one of the pre-set paper sizes e.g. 1:2
  2. Export the drawing as a PDF, helps to delete the border and info panel first
  3. Open the PDF in Photoshop, default open settings should be fine
  4. Scale the image back to 1:1 e.g. 200% in this example
  5. Adjust the canvas size to your desired paper format, ensuring the image itself stays the same size
  6. Save as a PDF again
You should now have a PDF file with a full size drawing, albeit with a slight loss in resolution
5 years and still no solution.
So how do I send a 1:1 pdf export of my Eg 10ft surf boards for outline cutting full deck pads and board bags etc. etc.
salesUD372
Observer
Observer
Still no resolution to this ?  In Soldworks you have a custom size option for drawings.
Totally shocked this option is not available in Fusion as one would have thought its a simple one to implement .
whatwhatwhoa
No solution in 2021.
Super frustrating as any other drawing programs support custom sheet size.
ClintBrown3D
Hi All
The good news is that custom sheet sizes is one of the enhancements that we are planning to add to Fusion. It's on our roadmap (under Management).
This is a highly requested feature and is one of the projects that are currently in the early planning stages.
Clint Brown
Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Sean3073
"Autodesk", When do you expect custom sheet sizes to come out? In my case I own a higher end printer and a very common and useful sheet size is "legal" which is 8.5 x 14 inches. Very common size. Most printers can take this. If Fusion / Autodesk would add just this one select and maybe later add custom sheet size it would make my life so much easier and I am sure I am not the only one. A lot of the other sizes that are selectable are not common at all for your normal business man/woman with the equipment they have. Respectfully, Sean
ClintBrown3D
Hey @Sean3073
Regarding your request for adding the "8.5 x 14 inches" size, I will check with the team to see what the impact of adding this additional sheet size before then would be. Give me a few days to investigate.
Clint Brown
cisoboy
Observer
Observer
So, next 5 years ?
jesper2165
Observer
Observer
Any news about custom sige sheet drawings
ClintBrown3D
Hi @jesper2165
Thank you for showing interest in custom paper sizes, this is one of the projects that I am really excited about seeing in Fusion 360.
We don’t generally publish release dates for new features, until the features are ready to be released, this is done in the What’s new blog posts. We may sometimes announce upcoming features in a blog post.
At this point, it is still in the backlog under "Management" (shown by the grey colour). What I can share, is that feature is on our medium term roadmap. Keep checking back, the roadmap is updated after each release, as soon as we start work on it, the status colour will change.
Clint Brown
jesper2165
Observer
Observer
Thank you for your answers ☺️
Are there any way around this I need to print something that is around 1100x800 mm on my plotter but I can’t figure out if there is an alternative way of doing it it has to be precise so to put it in 2 papers is not an option for me
Best regards Jesper
ClintBrown3D
Hi @jesper2165
Take a look at this article I put together on calibrating prints, with some experimentation, you should be able to get it spot on : https://clintbrown.co.uk/2021/04/08/fusion-360-calibrating-11-prints/
Clint Brown
In my use case, I would like to export a dxf file of a part I designed to send to a CNC. In this case, I'm using someone else to do my cutting, and using the manufacture workspace is not an option (not my CNC machine). I need to export 2D DXF file so it can be imported for manufacturing. My normal workflow is to pull the model into a drawing to get a 2D DXF, but when my parts are larger than the sheet size allows, I run into issues.
It would be nice if there was an easy way to export a 2D DXF of a file, and also a way to create custom sheet sizes for this use case, as well as all the others mentioned here.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
