I am designing some clock bezels (see attached picture) with lots of dials and a large number of numbers at different sizes;
The idea is that the numbers are printed separately with a different colour and inserted into the dials.
To do this I need a 0.2mm gap between the numbers and their associated cutouts in the dial in order to get insertion clearance.
I can do this with "Press Pull" as can be seen in the attached image of the number ""2", however it is very difficult to do that for numbers with lots of curves.
Ideally I want a way to create a path around the numbers in a sketch which is 0.2mm all around.
Anyone got any ideas?
