Creating a flat Voronoi pattern with constant width lines between the shapes
Message 1 of 1
I'm looking to create a flat voronoi pattern for sheet metal laser cutting with a constant width lines between the shapes for aesthetic and constructional reasons.
I've tried using this plugin for that:
https://apps.autodesk.com/FUSION/en/Detail/Index?id=1006119760063675415&appLang=en&os=Mac
But the lines it creates are not with constant width and it's not too parametric here are the results:
Generated voronoi patternGenerated voronoi pattern
Any clue to how may it be done properly even with other softwares with abilities to convert the sketch to DXF and adjust the pattern with mm?
Thanks for helping!
Replies (0)
