Project File: http://a360.co/2dwLRb6
I am trying to create a sketch on the larger end of an arc section so I can use the sketch points for alignment. I have created points for the midpoint of the arc section and projected them onto the component surface, but they are not "attached" to the component. When I use the alignment tool to attempt to move the arc section to the origin, only the sketched lines move. I want to be able to move the arc section itself.
On a similar note, reading through the October 5 update release notes, I noticed:
Measure an Arc radius – Previously when you did this, the Measure tool only gave you a distance between 2 points. Now you measure an arc sketch, you’ll see the Radius right inside the command dialog under Selection 1. Another great idea implemented!
I would like to measure the radius of curvature of the arc section as well, but I could only get the measure tool to show the distance between two points. I verified I am on the current version of Fusion 360.
Thank you
