Create a faceted face in Fusion 360
mamassey
mamassey
II'm struggling to create something that seems like it should be easy.  I just want to create a rectangular box, create a diagonal edge, then move the opposite vertices downward as shown in the photo below.
I tried using sculpt, but I don't think that is the right approach.  I also tried drawing two separate sketches on different sketches planes and using patch, but I couldn't get patch to form faces between the two sketches.
What would be the 'right' way to draw something like this?
davebYYPCU
Can be done with a splitting plane,
Draw the axis line in a sketch on the top face.
Use the line for a Plane on Angle, my pic is 5 degrees,
Split Body - with the inclined plane as the cutter.
Same for - 5 degrees, etc.
Hide the offcuts or the Remove command.
One way.....
mamassey
Thanks.
Thats a good solution.
miguel.palma82
Hello @mamassey
create a plane through 3 points, and then use that plane as a split tool.
Miguel Palma
Autodesk Student Ambassador
sanket223.patil
I also have an Idea on it .
You can use a loft command to cut that section . Means first sketch on small length face , the sketch will be triangular and then use loft select the sketch and then the last point , so it will cut the section and you will get , what you want . and again same for other side .
Sanket Patil
Mechanical Engineering
Expert Elite
chrisplyler
You can also do the Split Body trick with a sketch line as the tool instead of a plane.
Or you can use any other body to Combine>Cut away part of the first body.
Or... well, there are lots of ways to do this.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
