Coping intersecting sheet metal profiles while still be able to generate flat pattern.
TinWhisperer
TinWhisperer
I am looking for some work flow to be able to create "coped" custom sheet metal corners( intersections) .
What kind of work flow can I take to develop these profiles with custom copes to generate flat patterns for my plasma to cut.
in this case the material is 1/8 aluminum.
the green and yellow profile in the example would be cut to fit the red and blue profile.
there would be a couple small bit to take off on the red and blue profile too.
ultimately I would want to end up with 4 custom profiles that I could Nest , plasma cut, bend and weld out with a minimum of gaps.
A plasma cutter can only cut straight through the material ( perpendicular )  so the flat pattern would have to reflect that.
Any suggestion how to achieve this?
I would also be valuable if I could go back in my history and change the original opening size and all those changes would carry through the history smoothly.
Replies (21)
TinWhisperer
This project is done and installed.
TheCADWhisperer
Nice!  What would be a good time for me to come up and take delivery?
Type a product name
