Converting .txt to STEP (tried renaming)
I've run into an issue where a CAD file I downloaded online is recognized as a .txt file instead of a .stp and I can't see the component when I upload it to Fusion. On my Mac, I tried renaming the file by removing the .txt extension and replacing it with .stp but that doesn't seem to convert the file. Any ideas on how to properly upload it to Fusion as a STEP? Thanks!
kate.raskauskas
Hi @Anonymous,
Can you please link me to where you downloaded the file so I can take a look?
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
kate.raskauskas
Hey @Anonymous,
Did you still need a hand with this? If so, can you please link to where you downloaded the original file?
Kate Raskauskas
Try this, it worked for me.
1.-  Choose a .step file that knows it works (opens in autodesk inventor) and save a copy with other name
2.- Open it with txt editor and erase the text.
3.- Open the .step file that you want to open with inventor with txt editor too and copy the text.
4.- Paste the text in the .step copy file (step 2) and save it.
5.- Open the file (step 4) with autodesk inventor.
It should works
Just ran into this issue again and forgot I posted this. I figured out the solution and it's actually super simple though not so obvious!
Open the .step.txt file in TextEdit > Holding the alt/option key, click "File" in the menu bar to bring up the "Save As" tab > Click "Save As" > Remove the ".txt" extension in the title, leaving only the ".step" extension > Uncheck "If no extension is provided, use '.txt'" > Upload to Fusion.
FlyinBrian
Also had this same problem just now. Appreciate this post! Did as suggested and it worked great.
tdowling2BZ93
Community Visitor
Community Visitor
It should works
THIS WORKS. THANK YOU
