Converting Mesh to Solid
vangalvin
vangalvin
I have an STL of a skull i have cleaned up and converted to what I thought was a body. Using Mesh Mixer I changed the original STL to a solid then brought it in to Fusion, reduced the mesh then converted it to a BRep.
Now i want to add a cylindrical extrusion to the bottom however it is not acting like a normal body would, I can cut and intersect the skull but I can not join an extrusion to the base of the skull.
I have noticed the icon does not appear as a normal body would so not quite sure as to what I have done wrong.
Oceanconcepts
Your screenshot is just too small for me to tell but the icon doesn't look like a solid, which has this type of icon:
It appears to be maybe a surface body?
Or still a mesh?
The icon identifies the type of body.
Attempting to make a solid out of a mesh like that might result in a lot of errors or gaps. If you have a set of surfaces you can try using the Stitch tool and adjusting tolerances to try to get to a solid.
Maybe try uploading a larger screenshot?
- Ron
Mostly Mac- currently M1 MacBook Pro
vangalvin
Yes it appears that it is an open model and for some reason will not close, I tried the stitch option but it keeps coming back with nothing to stitch.
Is there any way to analyse the mesh to see where the open bit is?
vangalvin
Sorted it 🙂 Opened the model in an application called Netfabb and did a repair on it, seems there were 2 items that had not been stitched. then brought the repaired  STL in to Fusion and converted it perfectly!
Thanks for the pointer regarding it being an open model not a closed one.
