Contsruct axis
alaher
Contsruct axis
alaher
Hi
What is the meaning of axis in Contsruct part ? I understand planes but could You give some examples of using axis. Maybe somewhere here is but I didn't find...
marshaltu
The examples of using axis are Revolve command and some Joint-related commands.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
JamieGilchrist
Hi alaher,
here's another example of using a construction axis.
Lets say you have a cylinder and you want a plane to go through the center.
you need an "edge" to use the Plane at Angle command
so you first make an Axis through Cylinder/Cone/Torus command to get the "edge" for the plane
hope this helps.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
