Constrant options not popping up. Example, Horizonal / Vertical not giving me option on which I want to apply.
do a screen cast of what you are trying to do, you may not be doing something quite right.
If you dont know what screen cast is it's a screen capture program ADSK has for fusion 360 that's free.
also haveing your modle a a very clear explantion of what you are trying to do help a lot
Hi @papae93,
I assume that you are referring here to skech constraints:
Here's a bit of background about this: Originally, Fusion had separate horizontal and vertical constraints. However, this caused some confusion, because it is not often obvious in a sketch which way is "up" (vertical). So, customers were confused because they would hit "vertical" and their geometry would radically change.
So, instead, there is now just one command. If the geometry you select is nearer to horizontal, then a horizontal constraint will be applied, if the geometry is closer to vertical, a vertical constraint is applied.
Generally, the feedback has been positive, but of course some users would prefer more explicit control.
We appreciate any feedback you might have.
Jeff Strater (Fusion development)
what tutorial was it, it may be out of date,
