Concave lofting between 2 planes?
I want to create a shape like in my attached photo.
What's the best way to do that? I'm a beginner and my guess was to create a base plane, an offset plane, and then fillet the edges, but the fillet doesn't make the sides concave.
davebYYPCU
I extruded a plate, then sketched a circle, radius about the same as the plate thickness,
Sweep Cut the circle (or your shape in this sketch) along the four lower edges of the plate,
There are always a few ways....
SaeedHamza
Check this screen cast please
kind regards, Saeed
Saeed Hamza
TrippyLighting
How about using the screencast tool and embedding those directly into the post ?
There is a sticky post on top of this forum with Tips-&-Tricks that includes a tip on how to create and embed screencasts.
SaeedHamza
Thanks @TrippyLighting for the tip
From now on I'm using that
regards
Saeed Hamza
Thanks for the post. It worked!
This is exactly what I needed. Thank you!
Type a product name
