Component Size Based on Another Component
autodeskLUQB9
autodeskLUQB9
Hey all,
I have 2 "block" components for which I am attempting to create a little table with dimensions based on the block components.  I was attempting to add sketch dimensions based on the projection of the block components onto the table sketch.  But when I finish the table sketch it does not look as I expected.  Any ideas what I am doing incorrectly?
Thank you!
Table Sketch:
What I see when I finish sketch:
TheCADWhisperer
davebYYPCU
That sketch is not fully defined, the right side 20 dimension is flipping, because you didn’t prevent it.
Might help....
autodeskLUQB9
Thank you for the input.  I figured out that there was...something in the block component that was throwing things off.  It almost seemed like a residual sketch from a different component that I must have copied into the block component.  As soon as I deleted that and defined the sketch dimensions they worked as expected.
