& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I have managed to combine two bodies (Modify-Combine)
I rightclick the new component, and create a STL file fine.
Only issue is that in the slicer it is printed as two bodies standing together, and not as one.
The mesh is separate. What am I doing wrong?
Hi @loekkegaard.
Without seeing the files I will bring here some ideas:
1. Did you check the STL for errors after exporting?
2. I'm not used to Cura, but Simplify 3D has a option called Separate Connected Surfaces. Could you look for something similar and see what happen?
@loekkegaard Did you choose to keep tools? If so, turn the visibility of the bodies off, sending multiple bodies/components can create this type of result. It can also help to test by using the "Make" tool and sending the single component directly to the slicer.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
