Coil onto a helical path
C.FOTI
C.FOTI
Is it possible to have a coil follow a helical path? In the picture attached, I'd like the straight coil to follow the path of the helix.  Having searched the forums, I don't see anything for Fusion.  Can this be done in Fusion?
HughesTooling
The best way is to use sweep in the patch workspace. See attached file.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
I tried to pipe the last file I uploaded and Fusion fails. Reducing turns on both helixes doesn't seem to help either. I made the first helix a smaller diameter and less turns on the second and got it to work in the attached file but it is not that robust. Sure this used to work better.
Mark
Mark Hughes
C.FOTI
Thanks, Mark @HughesTooling .  The 2nd pic is generally the shape that I'm after, with some tweaking.  However, I may have forgot to mention that I need this to be shelled, so the feature will be hollow (like a straw). Hopefully that's not the straw breaking the camel's back 🙂
HughesTooling
Pipe does have an option for hollow and it works on the second file.
Mark Hughes
