Change the font of tables
ehall2600
Observer Observer
ehall2600
Observer
Observer
I am very new to Fusion 360, so sorry if there is a simple solution I'm missing here. But while in a drawing, how can I change the fonts to balloons, tables, and lists?
By default, this font comes in as AGA Arabesque (which is unintelligible), but I can't see a way to change the font. I have made sure the user language is English | English, and my drawing preferences Font is listed as Times New Roman. I have closed and restarted, and done some Googling to no avail. Surely there's a way to change the font, right? See example of my tables below. Please help.
ClintBrown3D
Hi @ehall2600
Not sure what's happened on your system, the default font is "Arial", but the good news, is that it's simple to get back to this. Change your document settings, in there you will see that you can set your font under text
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
whittakerdw
That shouldn't be, but as mentioned the default is Arial font format. There is a check box for "Override or Restore Format Defaults Below". I would try to restore the defaults to Arial and see if it is still doing it, and if so then, I am not sure what is going on. I tried it in Times New Roman and it worked just fine for me.
ehall2600
Observer
Observer
Thank you @ClintBrown3D  and @whittakerdw. I'm still not 100% sure what caused the issue in the first place, but it's resolved now.
