Can anybody show me how to fix a componant out of date error?
This seams a simple problem. But I wish F360 would tell me what comonant is out of date.
Its about as infromitive as my wife !
Anyone with any ideas?
Replies (8)
schneik-adsk
Along the very top of the application there is an icon with the yellow triangle. From here you can access the get latest command to update the out of date component.
Kevin Schneider
hi kevin.
Thanks for the responce.
I have tryed that and it does nothing.
Can it be overided?
As a warning that will not let you do anything is just a pain.
I think it referencing data no longer availble. ether as it was not suposed to be there. or it was deleted because it was not relivent.
the part you see is imported by the way.
Any other thoughts or ideas.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
If you share me to the project, I would love to take a look and see if we can't find the source of the issue! My email is james.youmatz@autodesk.com
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
HughesTooling
I think your problem is you inserted a part then used Remove, Remove leaves the component in the design.
 you need to Delete the Remove then Delete the inserted part I think this image shows the problem
Mark
Mark Hughes
Owner, Hughes Tooling
humm! so I highlighted that piont in the time line. I get what looks like ghost data. Now When I shelled out £4k for that other parametric program.Man Frustrated if i didnt want something I highlighted it and pressed delete. which is what I think I done here. Did I do it wrong?
here have a look!
opps it looks like screen capture is different on a mac!
@James.Youmatz wrote:
Hi @Anonymous,
I will get to that now! thanks
HughesTooling
You need to right click on the remove icon and delete first.
Then right click the linked part and click delete again. I don't know how you've got all those Remove icons in your time line, the only way I can get them is by right clicking on a component and selecting remove. I've tried pressing delete in a few different combinations but it just deletes the part.
Mark
Mark Hughes
Well problem fixed thanks to James.
Well done that man!
Those over deletes were data that was needed from the imported file!
Good vibes all!
