arc/circle sketch not selectable
danielND6TD
danielND6TD
Hello!
I want to find the center of an arc/circle, but i can not select it with a tool, for example "construcción - point at center" or "sketch - sketch dimensión".
Also i have other problem. I have an arc tangent a line, and i can not diferentiate when finish the arc and start the line. Also i can not select with a tool.
Thanks so much.
lichtzeichenanlage
Can you File -> Export your design?
TheCADWhisperer
Are you in an Active Sketch?
Where are your sketch dimensions?
lichtzeichenanlage
@TheCADWhisperer: Unless constrains are visibel I guess @danielND6TD is in the active sketch. My 2nd guess would be, that @danielND6TD has create an arc with the center fare away that might be out of the window or just behind the sketch pallet.
@danielND6TD: Can you left click on the arc (select), than press d (for dimension), than move the mouse to the inside of the arc. A dimension line should be visible know and it should point to the center.
HughesTooling
Pretty sure with those black dots at the ends they are splines not arcs.
Spline on the left arc on the right.
Mark
Mark Hughes
Owner, Hughes Tooling
lichtzeichenanlage
You're right - splines. So the answer for @danielND6TD is: There are no center points available for splines.
danielND6TD
Hello, thansk so much for the answers!
TheCADWhisperer: Yes, i am in active sketch
lichtzeichenanlage: Thanks, but i don´t think this the problem.
: Is not a splines.
I don´t know why could not solucionate the problem, but i find other way to do what i want to do, so i solucionate. It was probably because i had little experience with the software.
One more time, thanks so much for the anwers!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
