- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to build a toy walking robot with the legs driven by linkages, and I'm using the "design in place" method--I first design the hip joint, then align the thigh segment to the hip, then align the shin to thigh, and after I design the limbs, I project the parts into another sketch to create the linkages. The issue I'm having is that I don't know how to set it up so that if I edit the pose of an upstream limb segment, the positions of the downstream limbs will update as well.
For example, when I create the shin, I move the origin to the knee joint, and then use the "Align" tool to align the part with thet high by aligning the Z-axis to thigh's origin point, and then hitting "capture position". This works great until go back in the timeline and change the position of the thigh, since the "capture position" doesn't update. I thought of creating a sketch immediately creating the part so I could create a revolute joint and attach the part, but then I'd still have to use the align/capture procedure to line the the parts precisely since it's not yet fully constrained, so it seems like I'm back to the same problem.
I would love to hear any ideas. Thanks!
Example of misaligned joint after editing an upstream limb segment.
Joints misaligned after editing upstream segment.
