Announcements
Adding O-Ring Groove on outside of cylindrical object
Zerb
Zerb
cant figure out how to add a groove into the part i have drawn the arrows to.  i will not be machining this part from this drawing, its more or less just needed for aesthetic reasons. hope someone can give me some pointers here, thanks in advance.
http://i39.photobucket.com/albums/e164/zerrb/07KTopPiece_zpsdb150b7d.jpg
Replies (9)
jeff_strater
I would just use the Torus primitive.  Something like:
my crude attempt at your design (minus a lot of details):
step 1:  create a workplane where you want your groove:
step 2:  invoke Torus.  Select this plane, select the center as the torus center, expand the inner diameter and torus diameter to be about where you want it, make sure the Operation is set to "cut":
and OK:
Hopefully this will work for you!
Thanks for posting
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Zerb
awesome! i see how this will work perfectly for what i need to accomplish.  my issue now is that im not able...aka doing something wrong....to find the center on the plane that i created.
jeff_strater
Yeah, my example was centered on the origin.  If that's not the case, then the easiest thing to do is first create a sketch on that plane, then Project the cylinder into the sketch:
Then, while still in sketch mode (that's important), you can pick the center of the circle in your sketch as the Torus origin :
then, the rest is as described above.
Good luck!
Jeff
Jeff Strater
Zerb
i just ended up making the torus the size i needed, then manually moved it into place. again this is purely for aesthetics. i will try your method though just to make sure i remember how to do it next time around.
AbdnAllHope
Just a bit of an FYI.  O-Ring grooves come in a variety of shapes and sizes, but I have never seen a perfectly round one.  Even if your groove is asthetic, it would look more "real" if it was square.
There are a lot of rescources out there, but here is a link to one I found with a quick search that gets the point across rather well.
http://ablesealanddesign.ca/category/O-Ring-Groove-Design/183.html
phil
Zerb
you make a valid point for sure! would there be a simpler solution to my issue if i were to go about making a "square" o-ring groove?
carl_bass
One way to do it is using the pipe command using the square profile. I showed what pipe did but then showed how to move the cut down the cylinder by making an offset plane and projecting the profile of the cylinder
https://screencast.autodesk.com/Main/Details/6cf40705-695e-4637-9ea9-5ea4dd1c2e98
And here's a different screencast that shows how to model a cylinder with a groove by drawing it into the sketch profile and then revolving it. This allows for more general profiles
https://screencast.autodesk.com/Main/Details/60b45141-cdd8-4a37-aa49-fba625ab0969
jeff_strater
those are great solutions, especially desigining the groove in the profile and revolving - this lets you put almost any shaped groove into your design (triangle, beveled rectangle, etc).  For a simple rectangular groove, you can also just use a Cylinder primitive the same way that I used the Torus primitive above (a rectangular groove in a cylinder is just another cylinder cut from it!).
Jeff
Jeff Strater
AbdnAllHope
I think that The Big Kahuna put this one to bed with his sketch profile / revolve example. Here is another contribution to the many ways one can accomplish this task. Attempt to keep it simple using primarily tools that can be found on the pie menu.
https://screencast.autodesk.com/Main/Details/3c31aefa-4b60-4bc3-a99e-777dd60fe0c1
phil
