Adding 3d texture
Adding 3d texture
Adding 3d texture
I'm looking to add some texture to create 3d printable terrains. Basically I have to add this texture https://www.cgtrader.com/free-3d-models/textures/architectural-textures/procedural-pbr-cobblestone-t... to flat surface so i can print it with bumps ect. Is there a way to do this in fusion 360?
TrippyLighting
No, not really. CAD software is the wrong type of software for this. Following the description provided with that texture you need to find a 3D modeling software (polygon and Sub-D based meshes) such a Blender, MoDo, Maya, 23DSMax, Cinema 4D that can work with the  substance painter plugin.
There are Blender plugins for that sort of brick texture that work directly with Blender and don't need Substance Painter.
leon_mueller27
Observer
Observer
For anyone stumbling across this thread: I'm currently working on an add-in that - among other things - can add textures and patterns to objects from images: https://github.com/lmueller27/Fusion360PatternsAndTextures
