Hi Guy's,
I like the new wood materials, but testing it on my robot it seems impossible to change the orientation? I'm probably missing something?
Here's a screenshot where you can see that the orientation of the sideplates is not correct:
Solved by chengyun.yang. Go to Solution.
You can use the texture mapping command to adjust 3D wood orientation. Select the body and use the context menu to invoke the texture mapping command.
Chengyun
Fusion Development Team
