Tool edit
Tool edit
veso58S5W
Message 1 of 9
Tool edit
veso58S5W
I duplicate the tool, or copy (what is difference?)
If I switch (in editing the geometry) from Inch to mm, I can not save the changes/new tool. Save button becomes Gray Inactive?
What I am doing wrong.
Replies (8)
Message 2 of 9
Chetan.Bankar
Hi @veso58S5W,
Thanks for raising your query onto Autodesk forum.
After changing the unit from Inch to mm are you also making any changes to dimensions of the tool/cutter profile? Can you supply an image showing the mentioned behavior so that we can help you in this.
Thanks and Regards,
Chetan Bankar
Global Product Support
Submitting & Viewing Support Requests | Web Support | Phone Support
Message 3 of 9
veso58S5W
Without changing anything, just clicking unit button (what is in Inch in this case) Save button becomes inactive.
Message 4 of 9
jeff.pek
I'm not seeing this.
Can you post a video of the whole process, so that we can see what you're seeing?
  Jeff
Message 5 of 9
veso58S5W
Here is video https://youtu.be/5_aKP2zsOmo
No mater what i do, change geometry or just change dimensions, happen same thing - Can't save the changes.
Grid changes from Inch to mm, and you can do any geometry changes, but CAN'T save anymore
Message 6 of 9
Chetan.Bankar
Hi @veso58S5W,
Thanks for supplying the video. I have convey this behavior to the development team. I will keep you updated on this.
Thanks for your time and co-operation.
Chetan Bankar
Message 7 of 9
jeff.pek
Thank you for the video. This has helped clarify that this is happening when you edit a holder.
We've created ticket CAM-13557 to track this.
Jeff
Message 8 of 9
veso58S5W
This is still ongoing issue. Please do something.
Message 9 of 9
olivia.struckman
Hi @veso58S5W , this should be fixed in the most recent update.
