Post Processing probelm
Message 1 of 22
since the last update i can't use my personal post or my cloud post and when i use the generic posts that suits my machine (milltronics) that won't select either but all the other generic post are selectable.
Any help would be grateful
Gary
Replies (21)
Message 2 of 22
GeorgeRoberts
Thanks for posting! Could you create a screencast showing the issue? Or possibly a few screenshots? Are the options not there for you, or does it just not let you select the post?
Cheers
George Roberts
Manufacturing Product manager
If you'd like to provide feedback and discuss how you would like things to be in the future, Email Me and we can arrange a virtual meeting!
Message 3 of 22
Hi
My post processor is a custom one that I modified from a Generic one (milltronics) and has been working fine for months if not a year now
I've inserted a screen shot of the problem hope this helps
Message 4 of 22
It only seem to be the Milltronics Generic and my custom posts that are not working
Message 5 of 22
Help Help Help I need this sorted i can't use the post processor
Message 6 of 22
jeff.pek
I take it the problem is that the OK button is not enabled? Just want to make sure I understand what you're showing.
  Jeff
Message 7 of 22
jeff.pek
I think the problem is with the "G18" property (under Properties).
Its default setting -- which displays as just "G18" in the dropdown -- is not valid. So, you need to choose one of the available values (ZX or XZ).
We'll have to look into whether it's expected that this must be explicitly set, or if there should be a better default.
Jeff
Message 8 of 22
yes thats correct  its not working with my custom post which it has be ok and not working with the milltronics Generic post it seem anything to do with milltronics it doesn't work it works with the other Generic posts.
its was fine until the last update
Message 9 of 22
i have the G17 active
Message 10 of 22
jeff.pek
Not sure what that means. Can you show me a screenshot with the Properties being displayed?
  Jeff
Message 11 of 22
Here you go
Message 12 of 22
jeff.pek
OK, in your case it's G17 -- vs. G18 in the Milltronics post.
If you click in that dropdown, you'll see that "G17" isn't actually a valid value -- it wants one of the items that shows in the dropdown.
You need to either choose one of those values, or adjust the post to accept the default value.
Jeff
Message 13 of 22
theres nothing in the drop down when i click on it it does do anything ? so how do i chance the post and were do i put it in the post ?
Message 14 of 22
doesn't do anything that should of been ....sorry
Message 15 of 22
jeff.pek
Can you PM me your post, so I can see how that property is defined?
  Jeff
Message 16 of 22
I Can send it to you here or somewhere else ?
Message 17 of 22
sent to you
Message 18 of 22
jeff.pek
Thank you. If you add the following section after the "properties" section, you should get values that you can select from in the dropdown.
Note that the G17 property definition allows a new "Unsupported" value, along with ZX and XZ. If you change the default value of that property in "properties", then your OK button should be enabled right away. This would look like this:
G17: "Unsupported" // set to "ZX" (right handed) or "XZ" (left handed) in accordance with your control setting - byte 79 - G18 plane select: XZ=0, ZX=1
Jeff
[Add the following below the "properties" section]
// user-defined property definitions
propertyDefinitions = {
writeMachine: {title:"Write machine", description:"Output the machine settings in the header of the code.", group:0, type:"boolean"},
writeTools: {title:"Write tool list", description:"Output a tool list in the header of the code.", group:0, type:"boolean"},
preloadTool: {title:"Preload tool", description:"Preloads the next tool at a tool change (if any).", type:"boolean"},
showSequenceNumbers: {title:"Use sequence numbers", description:"Use sequence numbers for each block of outputted code.", group:1, type:"boolean"},
sequenceNumberStart: {title:"Start sequence number", description:"The number at which to start the sequence numbers.", group:1, type:"integer"},
sequenceNumberIncrement: {title:"Sequence number increment", description:"The amount by which the sequence number is incremented by in each block.", group:1, type:"integer"},
optionalStop: {title:"Optional stop", description:"Outputs optional stop code during when necessary in the code.", type:"boolean"},
separateWordsWithSpace: {title:"Separate words with space", description:"Adds spaces between words if 'yes' is selected.", type:"boolean"},
useRadius: {title:"Radius arcs", description:"If yes is selected, arcs are outputted using radius values rather than IJK.", type:"boolean"},
showNotes: {title:"Show notes", description:"Writes operation notes as comments in the outputted code.", type:"boolean"},
G17: {title:"G17 Plane", description:"set to \"ZX\" (right handed) or \"XZ\" (left handed) in accordance with your control setting - byte 79 - G17 plane select: XZ=0, ZX=1", type:"enum", values:["Unsupported", "ZX", "XZ"]}
Message 19 of 22
Hi Jeff
Your a star thank you very much thats worked now i can catch up on lost work lol
once again thank you
Gary
Message 20 of 22
jeff.pek
FYI, we are working on a near-term Fusion update to fix the problem in the presentation in the dropdown (CAM-8710).
  Jeff
