Need help from the experts to get drag knife working with F360
I am new to CAM of F360 and need some help from the experts here.
I know currently F360 does not support drag knifes natively so I try to get some workaround to get my drag knife working with F360.
To keep it simple I want to test my 1st cut on some cardbboard (1mm thickness) with following contour:
In the upper left you can see the contour I want to cut with my drag knife. This contour can also be an inner part (cut out) of a 2nd contour.
To get the sharp corners the drag knife must move ahead the black contour, follow the red slope and come back on the black contour.
Now the important thing comes: if the drag knife enters the red slope it must be lifted up on Z-axis but still keep in contact with the cardboard!
This is shown with the green line and arrows. This is necessary because the red slope should not be cut through. It is just to guide the knife to the new angle. If the cardboard has a thickness of 1mm I think the knife should lift for 0,8mm to stay 0,2mm inside the cardboard to guide it. Here the steps the knife should do:
1. Move along the black contour until the end of the edge.
2. Lift the drag knife for 0,8mm (knife keeps 0.2mm inside cardboard)
3. Move the drag knife along the red slope to guide it to the new angle
4. Move the drag knife down and cut the next edge of the contour.
Since I am fairly new to CAM inside F360 I need some help what steps F360 can currently do.
Here some questions I have:
1. What CAM mode should I use? 2D, 2D contour, 3D, 3D contour?
2. How can I get the red slope? Is there currently any feature in F360 I can use or do I have to draw them by sketch?
3. How I can make the lift up / put down procedure at the start and end of the slope?
Thanks for any ideas from you...
