I was looking for any updates on the inclusion of a Mach 3 plasma post processor. I read through some of the posts that people had and I briefly saw what looked like a Beta version of Artsoft's plasma post processor, but am having trouble finding it again. Can you help, thanks in advance.
Andy
This post indicates that mach3 plasma uses M3 and M5 for start stop and suggested modifying the torchmate post.
https://en.industryarena.com/forum/fusion-360-plasma-cutting-option-mach3--339636.html
If that is the case simply change this function, lines 582-584.
function onPower(power) { writeBlock(mFormat.format(power ? 50 : 51)); // plasma on/off } to this: function onPower(power) { writeBlock(mFormat.format(power ? 3 : 5)); // plasma on/off }
I looked at the torchmate post and compared it to the post I use with my Dynatorch. I think my post is cleaner, the torchmate needs a bunch of options changes like coolant such. See the long description at the top the the generic torchmate post.
I have attached a sample program that I used to test the Hycut Plasma. I've also attached the modified post. Post some code and see if mach3 likes it. Please let me know. This hasn't need tested (works on mine but I don't run mach3). The file extension is .tap but it can be changed to anything you like.
I didn't find it. Maybe you can email them? Did you try the post I uploaded last night? Plasma posts are generally very simple, arc start/stop, and 2d path.
I didn't try it as of yet. My machine (burntables) has a torch height control as well. I was around this post when I saw it before.
Hello All,
We are working on the Mach3 Plasma post processor and we would be happy to get some feedback from you before we put it into the library.
Please use the link below to discuss and download it from the Ideastation.
https://forums.autodesk.com/t5/hsm-ideas/post-processor-for-mach-3-plasma-table/idi-p/6702918
The post is there: https://cam.autodesk.com/posts/?p=mach3_plasma
It looks very generic. Basically it's the same as what I posted. You should download from the link above and test it.
Do you have a g-code sample with your height control commands enabled? I don't see anything in the post that turns it of. On my controller it is done from the operator panel rather than g-code. Not sure about Mach3.
Actually I believe that my is turned on in the operator panel as well. Thank you for your help, I'll give it a try.
Andy
Hey all, thanks for the help. I downloaded that Mach 3 post processor and will try it out soon, thanks again.
Andy
