Excel setup sheet out of memory
friesendrywall
friesendrywall
Any ideas why I suddenly get errors on attempting to use the setup-sheet-excel-2007.cps post?
The regular post seems to work, this has been working..
Information: Configuration: Setup Sheet Excel 2007
Information: Vendor: Autodesk
Information: Posting intermediate data to 'C:\Users\Erik\AppData\Local\Fusion 360 CAM\nc\3030.xlsx'
Error: Failed to post process. See below for details.
Code page changed to '1252  (ANSI - Latin I)'
Start time: Tuesday, July 18, 2017 2:41:29 PM
Code page changed to '65001 (UTF-8)'
Post processor engine: 4.2.1 41304
Configuration path: \\FRIESEN-NAS\1tb\Haas Settings\setup-sheet-excel-2007.cps
Include paths: \\FRIESEN-NAS\1tb\Haas Settings
Configuration modification date: Friday, January 13, 2017 6:54:56 PM
Output path: C:\Users\Erik\AppData\Local\Fusion 360 CAM\nc\3030.xlsx
Checksum of intermediate NC data: b660fdd8138282c3661e03c1db02d574
Checksum of configuration: 37113de35c49252684c38f5b63957148
Vendor url: http://www.autodesk.com
Legal: Copyright (C) 2012-2015 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.3174
Error(\\FRIESEN-NAS\1tb\Haas Settings\setup-sheet-excel-2007.cps:213): out of memory
Failed while processing onSectionEnd() for record 50854.
Error: Failed to invoke function 'onClose'.
Error: Failed to invoke 'onClose' in the post configuration.
Error: Failed to execute configuration.
Stop time: Tuesday, July 18, 2017 2:41:29 PM
Post processing failed.
Matthew-R
@friesendrywall One thing that I can think of is that the post processor file (.cps) and the template file (.xlsx) should be in the same folder location.  Also, there have been some updates to the Setup Sheet Excel 2007 post processor and I would suggest downloading the most up to date post from the link below and placing those two files in the appropriate folder to access them when post processing your setup.
friesendrywall
I am still getting these, even with the latest setup sheets.
If I hand select portions of the operations, they all work ok, but as a whole I get out of memory.
My machine isn't out of memory either, I have 32gb and it is using less than half at present.
jeff.pek
Do you have a model you can share that triggers this problem?
  Jeff
friesendrywall
I can, but I don't want to do it publicly. Let me know how to get you a copy.
jeff.pek
Can you just e-mail it to me after exporting it?
Use jeff DOT pek AT autodesk DOT com.
Thanks!
  Jeff
fonsecr
Ticket CAM-3115 is assigned for this issue which has been fixed for the upcoming Inventor HSM and HSMWorks 2019 releases. Fix should go into Fusion around May time frame.
René Fonseca
Software Architect
