We would like to mill this from 2.5 " aluminum round stock. Is there a way to generate the G-code to mill a side and rotate it to the next side.
Solved by mhansen1. Go to Solution.
First of all, this question really belongs in the CAM subforum: https://forums.autodesk.com/t5/computer-aided-machining-cam/bd-p/2070
Second, yes, certainly possible. You will need to use Tool Orientation, although that is available only in Fusion 36 Ultimate.
The Fusion license for Hobbyists and Students/Instructors IS the Ultimate version
Thank you for helping me stamp out some ignorance. My confusion is How to set up the 4th axis in the software and /or the tool path. I saw a post that said to go to preferences and in the preview to select a box to enable the 4th axis. I don't see anything like that. Is there an A axis for the centerline of the indexer?
Tool Orientation is out of preview entirely now.
You simply need to enable it in the Geometry tab of the toolpath dialogue:
In this screenshot I have selected the large face for Z, and the edge close to the "camera" as X. In using a rotary axis in Fusion though you'll want to set the axis of rotation as your Z zero point.
I've attached the file if you wish to take a look. Open it by going to File -> New Design from File and browsing to the download location.
