Vogel's model of Fermat's spiral?
HenryGab
HenryGab
What's are some relatively easy ways to accomplish the following in a 2D sketch?
Create Vogel model of Fermat's spiral:
150-circle example150-circle example
r = c * sqrt(n)
θ = n * 137.508°
where θ is the angle, r is the radius or distance from the center, n is the index number of the hole and c is a constant scaling factor. The angle 137.508° is the golden angle which is approximated by ratios of Fibonacci numbers.
Given parameters for:
  1. A count of identically-sized circles (will later extrude as holes) to generate
  2. A diameter of each of those holes
  3. A minimum distance between those holes
I cannot explain either the spiral nor Vogel's model better than Wikipedia.  The picture shows an example that might be generated for 150 such circles.
Why?
I want to generate holes corresponding to such a pattern, in which to mount WS2818 "bullet" form LEDs (individually-controllable, weatherproof RGB LEDs).  These LEDs snap into 12mm holes.  Thus, if automated, this would simplify generating the patterns at multiple sizes.  The hard part is ensuring minimum distances between the circles (ensure minimum amount of material between LEDs, so less likely to break when they are inserted/removed).
I imagine this might be a repetitive process that has to adjust the initial LED starting point on the spiral.
1. Generate potential points on fermat's spiral
2. Test nearest-neighbor distances of those points to ensure minimum distance requirement is met
3. repeat with different starting point to find closest packing (within tolerance)?
Given the final resulting points:
4. Take final points, generate circle centered at each one.
BONUS: Given a border that contains those final resulting circles, and the final resulting points:
5. Generate Voronoi diagram
(The bonus is for creating partitions in a diffusing cover, with one partition per LED... it just looks neat that way)
kandennti
Hi @HenryGab .
It looked like a lot of fun, so I gave it a try.
# Fusion360API Python script
# Create Fermat's Spiral Sketch
import traceback
import adsk.fusion
import adsk.core
import math
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        skt: adsk.fusion.Sketch = root.sketches.add(root.xYConstructionPlane)
        initFermatsSpiral(
            skt,
            1,
            150,
            0.45
        app.activeViewport.fit()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def initFermatsSpiral(
    skt: adsk.fusion.Sketch,
    spiralR: float,
    count: int,
    circleR: float,):
        def drawSketch(
            pnts: list,
            radius: float):
            sktCir: adsk.fusion.SketchCircles = skt.sketchCurves.sketchCircles
            drawSketchHiSpeed(skt, True)
            [sktCir.addByCenterRadius(p, radius) for p in pnts]
            drawSketchHiSpeed(skt, False)
        def drawSketchHiSpeed(
            switch: bool):
            skt.arePointsShown = not switch
            skt.areConstraintsShown = not switch
            skt.areDimensionsShown = not switch
            skt.areProfilesShown = not switch
            skt.isComputeDeferred = switch
        def getPoints(
            r: float,
            theta: float,
            count: int):
            pnts = []
            for n in range(count):
                r0_Sqrt_n = r * math.sqrt(n)
                pnts.append(
                    adsk.core.Point3D.create(
                        r0_Sqrt_n * math.cos(theta * n),
                        r0_Sqrt_n * math.sin(theta * n),
                        0
            return pnts
        goldenRatio = (1 + math.sqrt(5)) / 2
        goldenAngle = 360 / (goldenRatio ** 2) #deg
        theta = math.radians(goldenAngle) #rad
        pnts = getPoints(
            spiralR,
            theta,
            count
        drawSketch(skt, pnts, circleR)
kandennti
If you look closely, you don't need 0°.
        def getPoints(
            r: float,
            theta: float,
            count: int):
            pnts = []
            for n in range(1, count + 1):
                pnts.append(
                        0
            return pnts
HenryGab
kandennti, well done on generating the points.  as you can see, the resulting pattern is very pleasing to the eye.
Since posting, I realized that the minimum distance between points is not dependent on the size of the holes needed.  And, the pattern has similar pleasing symmetry even when starting at a non-zero offset.  See alterations to getPoints():
        def getPoints(
            r: float,
            theta: float,
            count: int,
            offset: float = 0.0
            pnts = []
            for tmp in range(count):
                n = float(offset + tmp)
                pnts.append(
                        0
            return pnts
Therefore, it occurred to me that I could pre-generate any number of starting offsets, to find a layout where the minimum distance between holes was largest.  Too large a starting offset, however, would leave a hole in the center, which was not desirable.
I was able to find a minimum distance (for circleR = 1) of 1.6447709720806767 at offset 1.695397.
Given that the offsets are, essentially, static, and that the distance between points scales in direct proportion to spiralR, you have made it possible for me to try this directly.
Thank you!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
