Simple Drive Joint Example
cadop5R9X9
cadop5R9X9
I am trying to do something similar to the drive joint example here: https://forums.autodesk.com/t5/fusion-360-api-and-scripts/inverse-kinematics-robot/m-p/5901869#M944
However, my layout is different than the example.  The Joints are on the main level, not under a particular geometry.  I was wondering how to directly get the joint angle in its own context, without first getting the 'piston' component.
Basically I just want to write something similar to:
Rev1.setAngle(x)
ekinsb
The code below gets a joint using the name of the joint and changes it's value.
def run(context):
  ui = None
  try:
    app = adsk.core.Application.get()
    ui  = app.userInterface
    des = adsk.fusion.Design.cast(app.activeProduct)
    root = des.rootComponent
    joint = root.joints.itemByName('Rev1')
    rev = adsk.fusion.RevoluteJointMotion.cast(joint.jointMotion)
    for i in range(720):
        rev.rotationValue = i * (math.pi/180)
        adsk.doEvents()
  except:
    if ui:
      ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
Mod the Machine blog
cadop5R9X9
Hi Brian,
Thanks for the fast response.
When running that I get a traceback:
AttributeError: 'NoneType' object has no attribute 'jointMotion'
my imports are below, maybe that is an issue?
import adsk.core, traceback
import time
import math
def run(context):
    ui = None
    try:
            adsk.doEvents()
            time.sleep(0.1)
    except:
        if ui:
ekinsb
Do you have a joint named "Rev1" in the root component of your design?  I believe the itemByName is failing and returning None and so the next call on that variable is failing.
Brian Ekins
cadop5R9X9
Yes I am trying this on the file that I gave the screenshot.  I also tried renaming the joint and using that new name, but same error.  Are there issues with it not being assigned a geometry as it was in the post I had first found?
ekinsb
I think I know what it is. The UI makes this a bit confusing.  I suspect you create an as-built joint and not a regular joint.  They're two different animals.  Just change this line:
to:
    joint = root.asBuiltJoints.itemByName('Rev1')
Brian Ekins
cadop5R9X9
Excellent thank you! It works great.
