- Mute
- Permalink
- Report
I am an expert 3D designer and a complete novice with programming..... but want to do the following:
I have a Sketch and Extrusion with the word "LEFT 40" that I would like to quickly change to "RIGHT 60" (and a bunch of different extruded text in my design).
Using Scripts would it be possible to have a script do the following steps:
- Prompt me to select a sketch, I would select the sketch,
- It would grab the "only" text entity in that sketch
- Pop up a dialog box that I can change the text from "LEFT 40" to "RIGHT 60".
I want to change the Text in a sketch text entity, without editing each sketch, double clicking the text and changing it.
That is the core of what I want it to do, it would be awesome if it could do the following also:
- The script selects all the sketches in sequence and grabs the sketch text entity, lets me modify it and then moves to the next sketch.
- Also allows me to change the text height in the popup.
If you guys think this would be possible, then I am going to dive into it and work on it, but if not, I will not spend the time.
Any script examples that you may think would be helpful or similar, that would be helpful.
Thanks.
