It's really nice that model parameters such as sketch dimensions, extrude distances etc. can be named on the fly by typing a new name, the equal sign, and then the desired value. However to then get these named model parameters to show in a popup list when typing a parameter in, it must be dug up and favorited in the Change Parameters tool. I was just curious if there might be any scripting possibility to automatically favorite all custom named model parameters?
Solved by prainsberry. Go to Solution.
I just thought exact the same thing. I have no experience in making custom scripts for fusion but will follow this thread with interest.
Hi @jjurban55 .
'Parameter.isFavorite' is a read/write property.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-2ab75499-ce0d-4744-b6c5-e5a6fb4ac6cc
import adsk.core, adsk.fusion, traceback
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
try:
global _app, _ui
_app = adsk.core.Application.get()
_ui = _app.userInterface
des :adsk.fusion.Design = _app.activeProduct
# init UserParamete
length = adsk.core.ValueInput.createByString("1 cm")
prm = des.userParameters.add('test', length, 'cm', 'hoge')
# Favorite
prm.isFavorite = True
_ui.messageBox('Done')
except:
if _ui:
_ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Sorry, I misunderstood.
def run(context):
try:
global _app, _ui
# get ModelParameter
prm = getModelParameter_itemByName('test')
# Favorite
if prm:
except:
if _ui:
def getModelParameter_itemByName(
targetName :str) -> adsk.fusion.ModelParameter:
prm = adsk.fusion.ModelParameter.cast(None)
for comp in des.allComponents:
prm = comp.modelParameters.itemByName(targetName)
if prm:
return prm
return prm
Thanks @kandennti for the script! I've never tried scripting before with Fusion and don't know python, but pasted your script into a newly created script in Visual Studio, saved it then ran it in Fusion. After a little while a dialog box appeared that said "Done" and click ok. However after I tried naming a new system variable, it does not appear that it automatically gets favorited 😞 Any suggestions?
Try making the 'test' part the name of the desired parameter.
Hello @jjurban55 I think maybe what you were looking for was a script that would determine if the parameter had ANY user defined name? Here is another example where I assume any name that is not a "d" followed by an integer is something custom and then will add it as a favorite. Also FYI @Olle_Eriksson .
Nice script though @kandennti !
# Author - Patrick Rainsberry
# Description - Simple script to make favorites out of named parameters
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
ui = None
# This is not nnecessary but makes code complete work better
app: adsk.core.Application
document: adsk.fusion.FusionDocument
parameter: adsk.fusion.Parameter
try:
# Get various application objects
ui = app.userInterface
document = app.activeDocument
design = document.design
all_params = design.allParameters
# Lets count the number of favorites added
count = 0
# Iterate over all parameters in the design
# Note: Intentionally verbose to make it easier to follow.
for parameter in all_params:
is_named_parameter = True
# Check if first character is not a "d"
if parameter.name[0] == 'd':
# Check if the rest of the name is not a positive integer
if parameter.name[1:].isdigit():
is_named_parameter = False
# Check if it has a user defined name
if is_named_parameter:
# Only increment count if it wasn't already a favorite
if not parameter.isFavorite:
count += 1
# Set the parameter as a favorite
parameter.isFavorite = True
# Feedback message, uses Python Format String
ui.messageBox(f'All done! {count} parameters added to favorites')
except:
if ui:
Thanks a lot, I will try this in the next day or so when I am at my computer.
Thanks @prainsberry the script works great! My only last question is if it might be possible to somehow make this an Add-on continuously running in the background? Perhaps it could detect when the model parameter count changed?
Here is a quick way to do that. Basically it will check after every command. It's a little over the top in how often it would run, but it is such a quick execution you probably won't really notice it. Just create a new addin and paste this in:
#Author-Patrick Rainsberry
#Description-Continuously monitors Model Parameters for changes to name and then adds parameter to favorites.
import adsk.cam
import adsk.core
import adsk.fusion
import traceback
# Global variable used to maintain a reference to all event handlers.
handlers = []
def check_favorites():
# This is not necessary but makes code complete work better
count = 0
count += 1
# Event handler for the commandTerminated event.
class MyCommandTerminatedHandler(adsk.core.ApplicationCommandEventHandler):
def __init__(self):
super().__init__()
def notify(self, args):
event_args = adsk.core.ApplicationCommandEventArgs.cast(args)
# Will check favorites after every command completes for anything except the select command.
if event_args.commandId != "SelectCommand":
check_favorites()
def run(context):
global handlers
ui = None
try:
onCommandTerminated = MyCommandTerminatedHandler()
ui.commandTerminated.add(onCommandTerminated)
handlers.append(onCommandTerminated)
except:
if ui:
def stop(context):
global handlers
ui = None
try:
for handler in handlers:
ui.commandTerminated.remove(handler)
ui.messageBox('Stopped Favorites addin')
except:
if ui:
Works great, thank you! This Add-in should be made more widely available.
This is really great! Makes the new feature of naming parameters as you dimension actually useful. Greatly appreciated!
Your script seems to work perfectly so far as an add-in. I'm looking forward to using it more with the direct dimension naming.
Thanks @prainsberry
I was just made aware of an issue with this that caused the file to become "edited" constantly. The issue is that regardless of whether the named parameter was already a favorite I "set" the flag anyway. I think that is essentially telling Fusion that something "changed" in the file. I just made one tiny change to the code and I think it should solve the problem. Basically moving the last line of the check favorites function into the if statement. You may want to update your code if you are using this. Here is the updated version:
import adsk.cam
import adsk.core
import adsk.fusion
import traceback
handlers = []
count = 0
count += 1
def __init__(self):
super().__init__()
check_favorites()
def run(context):
global handlers
ui = None
try:
except:
if ui:
def stop(context):
global handlers
ui = None
try:
except:
if ui:
