onSlection event
onSlection event
JanNavratil
onSlection event
JanNavratil
I'm trying to create small addin to get the velues on select of random things in the graphic windows.
I was thinking that this should be ok but, I'm not getting anything when I select entity.
# Event handler for the select event.
class MySelectHandler(adsk.core.SelectionEventHandler):
def __init__(self):
super().__init__()
def notify(self, args):
eventArgs = adsk.core.SelectionEventArgs.cast(args)
# Code to react to the event.
ui.messageBox('In MySelectHandler event handler.')
 Is there any sample of event on select? with message box or something?
Can any1 help me please?
Jan
kandennti
Hi @JanNavratil .
It is necessary to implement what is described in Help.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-2ACFFC2F-458B-4740-93B8-CCC56638D8AA
I made a simple Select Event sample.
I think you will need a code that is at least this long.
#Fusion360API Python script
#Author-kantoku
#Description-Select Event Sample
import adsk.core, adsk.fusion, traceback
_commandId = 'SelectionEvent'
_SelIpt1ID = 'Selectioninput1'
_handlers = []
_app = None
_ui = None
class CommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            adsk.terminate()
        except:
            if _ui:
                _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-2ACFFC2F-458B-4740-93B8-CCC56638D8AA
    def __init__(self):
        super().__init__()
        _ui.messageBox('In MySelectHandler event handler.')
class CommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
        try:
            cmd :adsk.core.Command = args.command
            onDestroy = CommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onSelect = MySelectHandler()
            cmd.select.add(onSelect)
            _handlers.append(onSelect)
            inputs = cmd.commandInputs
            i1 = inputs.addSelectionInput(_SelIpt1ID, _SelIpt1ID,  _SelIpt1ID)
            i1.setSelectionLimits(0)
        except:
            if _ui:
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        cmdDefs = _ui.commandDefinitions
        cmdDef = cmdDefs.itemById(_commandId)
        if cmdDef:
            cmdDef.deleteMe()
        cmdDef = cmdDefs.addButtonDefinition(_commandId, _commandId, _commandId)
        onCmdCreated = CommandCreatedHandler()
        cmdDef.commandCreated.add(onCmdCreated)
        _handlers.append(onCmdCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
JanNavratil
Thank you for the sample. cool!
Jan
JanNavratil
Again, thank you !
Can I ask you, is there event for CAM strategy creation or toolpath in manufacturing part?
I was not able to find it in the documentation.
Jan
kandennti
If you look at this Derived Classes, there seems to be no event related to CAM.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-8fe1eb12-c1dd-4bb5-b8f5-18ec63a5f464
If you use the Application.registerCustomEvent method, you may be able to do something, but it seems difficult.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-29BB6E92-6553-4AF8-B00E-63B8956B44B3
