Hi!
In my script I used attributes.add to assign attributes to a BRepBody. When this body is used for a pattern or mirror feature the bodies created doesn't share the assigned attributes. I was wondering is this the desired effect?
Other features, for example, Copy creates a body with the same attributes as the original one.
I am looking forward to your reply.
Dimitar
Hi @datanasovte .
We have created a sample that copies the Attributes of the original Body to the body of the pattern when the PatternFeature is selected in the timeline.
# Fusion360API Python script
# clone Attributes
import adsk.core, adsk.fusion, traceback
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
try:
global _app, _ui
_app = adsk.core.Application.get()
_ui = _app.userInterface
des :adsk.fusion.Design = _app.activeProduct
root :adsk.fusion.Component = des.rootComponent
# select PatternFeature
msg :str = 'Select Pattern Feature'
selFiltter :str = 'Features'
sel :adsk.core.Selection = selectEnt(msg ,selFiltter)
if not sel: return
feat :adsk.fusion.Feature = sel.entity
# Record marker Position
timeState = des.timeline.markerPosition
feat.timelineObject.rollTo(True)
# is Pattern Feature
if not hasattr(feat, 'inputEntities'):
# Return the marker Position
des.timeline.markerPosition = timeState
msg = 'PatternFeature only.'
_ui.messageBox(msg)
return
# get inputEntitie
refBody :adsk.fusion.BRepBody = feat.inputEntities[0]
# clone Attributes
for targetBody in feat.bodies:
cloneAttributes(refBody.attributes, targetBody.attributes)
_ui.messageBox('Done')
except:
if _ui:
_ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def cloneAttributes(
baseAttrs :adsk.core.Attributes,
targetAttrs :adsk.core.Attributes):
for groupName in baseAttrs.groupNames:
attrLst :list = baseAttrs.itemsByGroup(groupName)
for attr in attrLst:
targetAttrs.add(groupName, attr.name, attr.value)
def selectEnt(
msg :str,
filtterStr :str
) -> adsk.core.Selection :
try:
sel = _ui.selectEntity(msg, filtterStr)
return sel
except:
return None
Since Attributes are difficult to check, we also created this sample.
# Dump BrepBody Attributes
# check
def run(context):
try:
global _app, _ui
msg :str = 'Select BrepBody'
selFiltter :str = 'Bodies'
while True:
if not sel: return
body :adsk.fusion.BRepBody = sel.entity
dumpAttributes(body)
except:
if _ui:
def dumpAttributes(
body: adsk.fusion.BRepBody):
dumpMsg(f'-- {body.name} --')
attrs :adsk.core.Attributes = body.attributes
for groupName in attrs.groupNames:
attrLst :list = attrs.itemsByGroup(groupName)
dumpMsg(f'{groupName} : {attr.name} : {attr.value}')
def selectEnt(
msg :str,
filtterStr :str
try:
return sel
except:
return None
def dumpMsg(msg :str):
adsk.core.Application.get().userInterface.palettes.itemById('TextCommands').writeText(str(msg))
Hi @kandennti ,
Thank you for sharing the way you deal with that issue. I really appreciate it.
Your solution is fine but you have to remember to execute it for every pattern and that might lead to error and also it is an additional step, which according to me should be automatic that is why I was hoping to get an answer from someone from Fusion 360 development.
Currently, the only way to do this would be for a human to start the script and process it in order from the top of the timeline.
(Perhaps this could be done if you have a CustomEvent that monitors periodically.)
PatternFeature is probably not supported at the moment, but when CustomFeature becomes available, I feel that I will be able to create the command I want.
