How to draw an Archimedean spiral using Python
How would one draw an Archimedean spiral using Python code? I've been trying to draw one using arcs with the
addByCenterStartSweep() method. Also tried using Ellipses but nothing has worked.
marshaltu
I am not sure if you have tried to draw an archimedean spiral by UI in Fusion 360. If it worked for you, we can probably draw it using Python API. If so, please share which commands you use to do that in UI? Otherwise it would be a limitation of Fusion 360 and we have to add the functionality before it is exposed by API. Please log you request to our idea station.
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/idb-p/125
Marshal
Marshal Tu
Fusion Developer
I couldn't find anything using the UI. I tried using sketch arcs on the UI but could not create an archimedean spiral.
This is the best I could do on my own, using my own script I made using arcs. It could just be that I'm not using the correct formula for drawing spirals.
Below is the code I use to make the spiral sketch seen below.
def MakeSpiral(Wirediameter):
app = adsk.core.Application.get()
ui = app.userInterface
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
rootComp = design.rootComponent
sketches = rootComp.sketches
sketch1 = sketches.add(rootComp.xZConstructionPlane)
sketchLines = sketch1.sketchCurves.sketchArcs
StartPoint = adsk.core.Point3D.create(-(Wirediameter+2.0), 0, 5)
degrees = 350
n = 0
while(Wirediameter > .1 and degrees > 0):
if(n == 0):
x = StartPoint.x
y = StartPoint.y
z = StartPoint.z
middle = (x+Wirediameter)/2
middle2 = (y-Wirediameter)/2
CenterPoint = adsk.core.Point3D.create(middle, middle2, z)
SweepAngle = degrees * (3.14 / 180)
arc = sketchLines.addByCenterStartSweep(CenterPoint, StartPoint, SweepAngle)
Wirediameter = Wirediameter - .1
degrees = degrees
StartPoint = arc.endSketchPoint
n = n + 1
else:
x = StartPoint.geometry.x
y = StartPoint.geometry.y
z = StartPoint.geometry.z
Wirediameter = Wirediameter - .2
degrees = degrees
n = n + 1
marshaltu
I am aware you have created a request in our idea station. Thank you. I also searched and found an user did similar thing to you. Maybe you can borrow the idea.
https://forums.autodesk.com/t5/fusion-360-design-validate/i-am-trying-to-make-a-scroll-shaped-part/m...
Marshal
Marshal Tu
Fusion Developer
BrianEkins
I've just created a blog post that will hopefully answer your question.
https://ekinssolutions.com/creating-equation-curves-in-fusion-360/
Brian Ekins
