Editing and Debugging stopped working
oafak
oafak
It appears that this was caused by the September 2020 update. Is there a particular version of the Python Extension to use with the change in debugger? Or why is the connection with Visual Studio Code (Windows 10) not working as before? Are others facing this problem?
kandennti
Hi @oafak .
I can debug in the following state.
・ Win10 Pro
・ Fusion360 Ver2.0.9009
・ VS Code Ver1.49.2
・ Ms-Pythpn Ver2020.6.91350
oafak
Thanks for the response.
My debugging started working again after 45 minutes as I was in the middle of debugging script when the update happened. Thanks very much, it seems to be working now with no change from my part. I read that the Debugging tool in the VSC changed. It does not appear that we need to do anything at our level about that.
BrianEkinsADSK
You should be able to use the latest version of the Python extension now.
oafak
Thanks very much Brian. I am assuming though that we must still use version 3.7.6 of Python Interpreter. Is that correct? My system is back and working very well. Thanks for the excellent work your team is doing.
