October 2020 Product Update V.2.0.9142 has broken all my plugins purchased from the autodesk store.
i get the contact plugin author error plugin cannot run plugin. manual start will not work.
I contacted the author of the plug in however now my work day is ruined as i rely on these plug ins.
i guess it has something to do with all the sketch changes in these update.
anyone else have this problem?
Hi @superclod3W6YQ .
It seems that the cause is that the assignment process for read only property was correctly prohibited in the recent Update.
It is also reported in this forum.
・ ToolbarPanel.isVisible
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-f660e4f0-bdd5-469b-9d7e-eb2a8be38050
・ ModelParameter.unit
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-7f50df6a-c61d-481b-b662-ee443702c457
There may be others.
Another issue I've found in my own code is that the SWIG collections don't seem to support negative indexing any longer. Previously, you could use the pythonic [-1] indexing to refer to the end of the list, but that no longer works.
Same here. I can't understand why?
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
Not able to pass [-1] as valid index in a list looks a bug to me. Created ticket FUS-74230 to track this. Thank you for posting it.
