The easiest way to accomplish this is to find a copy of the original Release 10 (for DOS?) .LIN file.
Failing that you need a custom LSP routine to export Linetypes from your current drawing. They exist, but you'll have to dig them up yourself.
Failing THAT you can create an empty drawing/template containing all your Linetypes and then cut & paste them as needed.
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
