250 Vistas, 1 Respuesta
Solids over my writing when I insert PDF
HI everyone,
I have a little problem, when a insert a pdf in Autocad, Some time I have some solids over my writing I can delete them and see after writing below, but when I insert my Pdf there is a way to see it's solid ???
Thans for your help everyone
See Attchments
vinodkl
en respuesta a: Anonymous
You need to uncheck the "solid fills" option while importing the PDF, doing so will not import any solids into the drawing.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
