Dxy00
522 Vistas, 4 Respuestas
AutoCAD 2020 can't osnap to blocks or Xrefs in different viewports
I am using AutoCAD 2020 simplified-Chinese version and everything is set to default except 4 apps (AutoAlign, ReplaceBlocks, Drawing Purge and Change Block Base Point) I downloaded from Autodesk App Store.
After making two ViewPorts in model space I find that osnap doesn't work properly between ViewPorts.
For example, in model space when you use move (or copy) command only in ViewPorts 1, the osnap works fine to blocks and Xrefs in ViewPorts 1 . However when you want to Move (or copy) form ViewPorts 1 to ViewPorts 2, I find that I can't osnap to blocks or Xrefs in ViewPorts 2. (While using Ctrl+Shift+C and Ctrl+Shift+V between ViewPorts, the osnap works fine)
That is frustrating and I am pretty sure that function woks fine in AutoCAD 2014 and I have test it with same brand new dwg files.
Is it a known issue and will be fixed in future with hotfix or service pack?
Etiquetas (1)
