375 Vistas, 4 Respuestas
Inserted Raster Image doesn't show completely in AutoCAD
I inserted over 50 JPEG format images into one drawing in AutoCAD 2013. But occasionally some inages does not displayed completely with blank stripes.  However when I zoom out the image to specific scale,it showed completely as normal without any problem.Does anyone knows how to solve this problem? Many thanks.
s.borello
en respuesta a: Anonymous
Have you toggled hardware acceleration to see if that makes a difference?  Have you plotted a PDF to see if what you see on screen plots that way?
en respuesta a: s.borello
I have tried to toggle the hardware acceleration, but there is no difference.When I plotted the drawing with images to a PDF, I can still see the blank stripes in the image. You can see the result from the attached screentshot.
Alfred.NESWADBA
are that always the same JPG's that fail to display?
Any chance to create one TIFF file from these tiles?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
Hi Alfred,
Not the same JPG file that fails to display completely. When I inserted over 50 images, there will be some that
doesn't show correctly.
