451 Vistas, 4 Respuestas
Automatic Dimensions
Hi all.
New user here.
2d foundation plan: Does a function exist that will automatically generate a dimension at each change in direction? (in lieu of selecting a dimension style then selecting each point to generate the dimensions)
pendean
en respuesta a: Anonymous
Nope, all dimensions are user created/driven.
Kent1Cooper
If you make the perimeter a single Polyline, there are routines out there that will dimension all edges of a Polyline, such as DimPoly.lsp, >here<.  Read more in that thread for background, optional approaches, links to other routines, etc.
Other than that, depending on the configuration, you may be able to use QDIM, which can at least do same-direction Dimensions on an entire side of things in one shot, though not the entire thing all around in one shot.
Kent Cooper, AIA
en respuesta a: Kent1Cooper
Thank you for the response.
Jason
en respuesta a: pendean
Thank you for the quick response.
Jason
