carrielester
584 Vistas, 5 Respuestas
Aligned dimensions not same as Linear
I am trying to provide dimensions on isometric views in paper space.  I have been able to place the aligned dimension correctly but I'm not getting the desired value.  Please see attached drawing, the isometric view shows a dimension of 3 11/16" , then shown in the top view as 4 1/2".  We do a lot of projects where isometric views are preferred but need to show the linear dimension.  So using the attached drawing as an example, (intended used with more complex assemblies) we would want to show that 4 1/2" dimension in the isometric view.  Is there any other way than editing the dimension text value manually?
Thank you.
