carrielester
582 Vistas, 5 Respuestas
Aligned dimensions not same as Linear
I am trying to provide dimensions on isometric views in paper space.  I have been able to place the aligned dimension correctly but I'm not getting the desired value.  Please see attached drawing, the isometric view shows a dimension of 3 11/16" , then shown in the top view as 4 1/2".  We do a lot of projects where isometric views are preferred but need to show the linear dimension.  So using the attached drawing as an example, (intended used with more complex assemblies) we would want to show that 4 1/2" dimension in the isometric view.  Is there any other way than editing the dimension text value manually?
Thank you.
en respuesta a: carrielester
Unfortunately AutoCAD does not dimension isometric in linear form. The only way to do this would be to use Plant 3D. Not the answer you were looking for.
Kent1Cooper
An easy option, if it's otherwise acceptable for you, is to do the Dimensioning in Model Space.
Kent Cooper, AIA
ara_neresesian
HI
I do like this (see attached)
carrielester
en respuesta a: Anonymous
I downloaded 3d plant and trying to do a test run but I'm unable to find out how to get the same value from a top view dimension in the isometric view.  I'm still getting different values.  Please see attached drawing.
Thank you.
GrantsPirate
Dimensioning in MS is so much easier but if you must do it in PS you can adjust the Measurement scale scaling factor for an isometric projection with a value of 1.22474487 (square root of 2/3).
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
