vinodkl
en respuesta a: Anonymous
I guess the line is drawn, but its too small to be visible with grids turned on. Try turning off the grid and the use command "zoom" and select extents for the line to be visible. You could use "RECTANGLE" command to draw 5x5 square. Type in command "REC" and pick a point, now select "dimension" and specify the length and width and the click again to end the command.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
