Alfred.NESWADBA
en respuesta a: Automohan
thank you for your screenshot, it shows that you have not installed any updates, please start with that!
The _ABOUT dialog should look like that:
Then please start command _AECDWGUNITS and make sure you have the correct units set in that dialog, after that start command _UNITS and verify that the same units are set inside that dialog.
Does _DATAEXTRACTION then work well?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
