- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
How to flatshot 3D to 2.5D with dimensions.
The 3D model is
I convert it to 2.5D with flatshot command and have hidden line in obscure line.
How to convert the dimensions to 2.5D.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
dimensions can't be used with _FLATSHOT, why is the needed?
The workaround which I could think of is to plot to PDF (or DXB) and then attach or insert the PDF ... but in that case dimensions are not any more dimensions (I guess that's why _FLATSHOT can't work with them).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I want the obscure line is hidden line and plot to PDF with dimensions.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Then change to a visual style (I used "Hidden" in the screenshot) that has "Occluded Edges" set to visible and run _PLOT then.
Drawing and PDF attached.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If I change to Hidden visual style,the line quality very low(See the PDF)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
have you tried to plot my drawing?
Compare your dwg/your visual style settings with my ones.
- alfred -
Alfred NESWADBA
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
