en respuesta a: mfoor2010
As far as grabbing screen images, you can either press alt+fn+print screen to capture the entire screen, then open Paint and paste (or ctrl+v) then save image wherever you want, or use Snipping Tool to capture any part of the screen, and "save as" to wherever you like. Both of these are in Windows Accessories in Start Menu.
If you can see the ribbon and at least some of the panels, but you don't have the "little triangle" buttons, I am not sure how to fix that...I can't seem to make them go away without closing the ribbon entirely.
Try command "ribbonclose", then "ribbon"  maybe turning the whole ribbon off, then back on will "wake it up"?
