10-31-2019
06:55 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-31-2019
06:55 AM
Not that it will make you feel any better, but I also had no problems copying to the clipboard the entire contents of your dwg file.
A few suggestions.
Option 1. Try narrowing down what you are copying to the clip board. try smaller sections until you find the area that is causing the issue, then something might be apparent.
Option 2. Use the WBLOCK command to Write out what you want from this file and then use the insert command to insert the block into the destination drawing, at that point you can explode or leave as a block.
Good luck,
