1305 Vistas, 5 Respuestas
Problem with TRIM command
As you can see in the attachments, when I use trim while zooming it cuts at the same time the extend line (and it is not taking in consideration the other lines that are intersecting the trimed lin), when I use it without zoming it gives me the wanted result.
Etiquetas (2)
