en respuesta a: dbroad
Hi DBroad:
checked all those, ATurned ATTDISP to Normal
set ANNOAUTOSCALE to 0
and did the OBJECTSCALE on entire drawing with 1:1 however when clicking a single block with annotation to try this I get a "no annotative objects in the seleection set" so the solutions provided did not correct the model space issues, I ahve nto attempted a print to see if the problem shows up.
Have attempted to hide the objects and or turn off layers to close the UNICODE/STANDARD text problems but the entire block assoiated with the unicode/standard texts turns off as well.
I was able to turn off the "DEFINE STYLES" layer to hide the issue but this does not seem to fix the file size issue.
Mark
